gas station canopy 2
deereman
44
An architect is wanting me to design a drive thru that has only 2 posts, similar to the structures they install over gas pumps. Has anyone ever designed one of these? Are the columns designed as a cantilevered column to resist lateral loads? It seem this is a very unstable structure. I've noticed that alot of the new canopies have 4 columns and the ones that have 2 columns have alot bigger columns than the older ones.
I should clarify that it was the roof that was moving up and down 1.5'. The roof itself looked like a blanket being shaken at the beach (and this was only a 30-40 mph wind). To be honest, I didn't even look at the column drift, but that's because I was so surprised (and focused on) by the amount of movement of the roof.
I'm sorry StructuralEIT, but are you saying FEET or INCHES?
If it is feet, then my only advice would be RUN!!!!!
FEET! It really was crazy, that's why I called.
Was it a two-post structure?
I checked one of these one time where it was not really stable - sort of a teeter-totter in one direction. The designer inadvertantly was relying on load-symmetry to "balance" things out. Otherwise they might have seen the deflections you are describing.
