waliq
- Jan 28, 2019
- 53
We want to install a duct at the outlet of Gas turbine. The temperature of Exhaust gases leaving the GT is 540 Deg C. There is also a duct burner installed, which when operated, raises the temperature of gases to 750 Deg C. Design pressure for this duct is 300 mm WC
We have asked the vendor if the following material is suitable for this duct
Outer surface : A36
Insulation : Rock wool (just beneath A 36 base metal) : thickness 120 mm
Insulation : Fiber mat (just beneath Rock wool insulation) : thickness 120 mm
SS 304 lining sheet, thickness 2 mm (inner side directly exposed to gases)
However, the vendor is saying that this is not possible as there is difference in thermal expansion of outer CS plate as lower temperature and inner SS place at higher temperature, which can damage the holding bolts/brackets for insulation arrangement and can distort the inner SS plate.
Now, I think that vendor's explanation is not applicable since SA 240 304 plate can be used till a temperature of 825 Deg C as per ASME Sec II, Part D.
It is requested to kindly advise if vendor's explanation is correct or not
Outer surface : A36
