Gas Turbine Generator Efficiency Calculation
noer_nu
3
0
0
SG
Hi All, I am a new engineer working with Gas Turbine Generator. I am looking for a way to calculate efficiency based on online parameters available.
Available parameter:
- Inlet air temperature (T1)
- Pressure compressor discharge (PCD)
- Fuel flow
- Turbine exhaust pressure (T7)
- Power turbine inlet temperature (T5)
- Power
The formula I found in textbox require data from enthalpy and something related to fuel composition.
Is there is any approach method to estimate efficiency with all online parameters above?
Nunu
All you need are three things:
[ul]
[li]fuel mass flow[/li]
[li]fuel enthalpy by mass (your choice to use LHV or HHV - LHV is typical)[/li]
[li]power[/li]
[/ul]
You need to get the units of fuel flow rate and power on the same time base (e.g. /second), and you need to get the energy units of fuel LHV/HHV and power the same (e.g. Joules)
Then you simply divide power by (fuel flow * fuel enthalpy) to get thermal efficiency
This is pretty elementary... Did you study mechanical engineering?
Two points
engines burn LHV (lower heating value). In simple terms HHV includes non receoveralble energy, espcially considering turbine alone without considering exhaust heat receovery.
Power can be shaft power, but for electric generation, you can only measure generator power, this will be less than the mechanical shaft power because of generator losses could be 2.55 for a small generator.
Lou Scannon, yes I am studying mechanical but specific to static equipment.
I am in a elementary level for rotating equipment :)
Thank you for your answer, really helpful.
Do you have any book related to gas turbine efficiency. I believe I should start from the book/references.
