Hi All, I am a new engineer working with Gas Turbine Generator. I am looking for a way to calculate efficiency based on online parameters available.
Available parameter:
- Inlet air temperature (T1)
- Pressure compressor discharge (PCD)
- Fuel flow
- Turbine exhaust pressure (T7)
- Power turbine inlet temperature (T5)
- Power
The formula I found in textbox require data from enthalpy and something related to fuel composition.
Is there is any approach method to estimate efficiency with all online parameters above?
Nunu
- Fuel flow
- Power
Nunu
