Kaadm
- Jun 28, 2012
- 32
Hello everyone,
One of our gas turbines generator need the adjustement of an orifice manual valve (istalled at the bottom of solenoid
valve in the torque convertor oil circuit), however, this valve is never adjusted on the other turbines.
The opening/closing of the solenoid valves is controlled by the turbine logic control.
We adjust the valve in order to get the self sustained speed of the turbine main shaft, also avoiding
the starter moter get overloaded.
I wonder why the valve need an adjustement at each start up for this turbine.
Thank you
Thank you
