  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Gasket
Open table.
Read table.
Know information about flange size, spec, fluid type + pressure + flow + temperature + safety and specifications requirements.
Apply knowledge.
yes - I am being slightly sarcastic. There is not information provided (from you) to help you with your question.
ok ....
There is one lube oil Cooler (S&T Heat Exchanger AES type).
Design Pr. Shell side 10.55 and Tube side 10.55
Design Temp. shell side 149 deg C and Tube side 75 deg C
Fluid Shell side is Lube oil and Tube side is cooling water.
shell ID 489 mm
Tube length is 3658 mm.
I think these informations are sufficient to help my question.
pls let me know if any thing else required.
What type of gasket should I select to design the flange?
