Product: PP round flat Lid, dyed dark brown. Injection gate on the male mould side to allow for the label to be applied on the female mould.
Label material: Multilayer PP white 65 microns
Since PP material is dyed dark brown and being injected opposite the white label, it fuses into the label to the label's full thickness with adverse aesthetical result on the label - it produces a brown circle of 2-3 mm in diameter.
Tried to keep the label cooler by replacing the mould part with a piece made in phosphorous bronze (cheap alternative to BeCu since no special mechanical strength is required. This reduced the mark diameter but did not solve the problem completely. Any suggestions please?
