GAL02
- Sep 2, 2015
- 55
Dear all, Good afternoon !
Regarding the subject matter Gate valve following is the situation for which I need your expert & experienced feedback.
We are working over Steam Super Heater (High Pressure High Temperature service) who's outlet isolation Gate valve not getting operate i.e.
Open or Close) by manual Gearbox (Actuator Damaged due to malfunction) and now Gear box Drive Bush catches the stem (Due to thread damage)
situation is as follows:
1) Super heater develop leakage & need to attend urgently.
2) To isolate super heater need above said valve (12" X 10" X 12" X 2500 # BW)which is not getting operate.
3) If we want to remove Gearbox it need valve to be close (which is not getting operate)the valve to install new gearbox.
4) If we try to cut the gearbox to remove inside Drive Bush then what will be the valve stem behavior when line under pressure
of 130 Kg/ Cm2 and Temp. 135 ° C
Pl. Advice what will be Valve stem behavior if it will be un supported when line is under pressure (130 Kg/ Cm2 and Temp. 135 ° C)
With regards
With regards
