Bflo,
I am still trying to understand your fixture. You have an accurate rod (Ø.0604/.0602?) to pick up datum face[ ]A. This controls[ ]X, Y, and two axes of rotation. You have a diamond pin that picks up two sides of datum face[ ]C, but clears the bottom of the hole. This controls the other axis of rotation. You have a flat face that picks up datum face[ ]B, and controls[ ]Z. Note how the flat faces contact at one point, only. There is no reason to assume they are parallel.
If this is a good, functional description of your part, then this is a good datum scheme. You might want to tighten up the diameter tolerance on your primary datum. Either that, or make sure you understand how your part works at anything other than MMB (MMC?).
JHG
