If the holes or any are located in angular face do we need to make angular face as datum? In order to locate the hole on the face. I have attached drawing in which 1st set rivet holes are located on planar face and other 2 sets are located in angular face. For 1st set rivet holes I used composite tol frame per guidelines created here. Can I use same Composite tol frame for other rivet holes which are located in angular face? Since the bottom frame as one datum pattern must be controlled w.r.t that datum.
