obewan9043
I have a GE Frame 9 Gas Turbine producing 125 MW at 11kv 50hz. I have step up transformer to 132kv to supply to the utility My problem is when I ran the SKM IEC short circuit analysis on the one line, my 6000 VAC bus is 155Ka and my 380 VAC bus il 2345 ka. Is there a way to reduce this short circuit? Thank you.
