Gear assembly animation in nx 7.5 1
OK, attached is another assembly where the only changes that I've made is adding a Datum plane to the 'Case' so that I can 'clock' one the gears so that it meshes better with the other gear. The other change was I replaced the '3D Angle' constraints on the gears with 'Orient Angle' constraints as they are more predictable, particularly if something is going to rotate more than 180°.
Now I've got this set up so that you can use the supplied GRIP program, 'animate_assy' to cause the gears to move. When you execute the program (File -> Execute -> Grip...) and when the first dialog opens, enter the name of the 'driving' expression, in this case the name 'angle'. When the next dialog opens, enter the follwing values:
Start = 0.0000
End = 360.0000
# os Steps = 100
Speed Factor (1-10) = 10
And then hit OK.
Note that in order for all of this to work, you need to fully open the assembly. In other words, do NOT use 'Partial Loading'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=f9b7f666-4bd0-42a4-be78-ebb5a7dbf678&file=GEAR_ASSEMBLY-JRB-1.zip
Thank You John for your support. One thing how to create the GRIP PROGRAM i have no idea about that.
The GRIP program, 'animate_assy.grx', is in the zip file I posted. You need to execute it as I've already described.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
