For many years, the wording on the side of the drum containing the lubricating oil we put in our helical geared speed reducers said Gear Oil. Our oil supplier always advised us to use Gear Oil for our application and not Gear Lube. We recently changed oil suppliers, which brought a brand change with it. The product supplied by the new brand is labeled Gear Lube. When I placed the 2 product description sheets side by side, the wording was essentially identical. Since the description sheets are the same, I guess it really makes no difference what words are on the side of the drum, but it would still be nice to crack the mystery. Any suggestions, ideas, comments any wish to offer about the difference between Gear Oil and Gear Lube, or if there is any, will be greatly appreciated. Thanks, K.
