Madness42
- May 21, 2005
- 12
Hello all
I am a bit new to this. Was wondering if you could help me.
This is my dilemma. I am looking to have some gear profiles laser cut. I know it sounds crazy. But thats what I want to try.
Therefore I need a very forgiving gear configuration. Very low tolerance values. This is not for a high speed operation. So wear and friction etc is not an issue.
I was considering an involute gear setup as from the little reading I have done they do not have to be perfectly aligned. There are 4 smaller gears that are operated by a very large gear. PCD 30mm (small) PCD 300(large) Gear ratio is not critical either. The 4 smaller gears fit inside the large gear. One at each of the compass points. That will be the only thing holding the large gear in place.
How do I draw the small gear and how do I allow for inacuracies in the laser cutting. Massive undercuts are fine if needed. But the less the better. How do I draw the large gear. Basically a sun gear.
Any help would be appreccited.
- Ryan
- Ryan
