Gear Tooth Geometry in NX 1
Josh2013
Has anyone dealt with drawing a gear in NX? something with correct involute and tooth geometry. If so what is the best way to go about that?
I have all the data just want to know what the best/most accurate way of drawing the tooth profile in the program would be.
I'm using NX 7.5
Thanks!
I played with it, In 7.5 it seems to require a "UG_KF_Execute" but in NX9 it requires both a "NX_GC_toolkit" and the "UG_KF_execute".
Tomas
I'm trying to use this too and running into the "License for NX china package isn't available" error (using a Mach 2 licence in NX 8.5). Can anyone give us more of a nudge in the right direction?
Thanks!
JHTH
NX 7.5.5 + TC 8.3.2.2
I spoke to my friends at Siemens, It's a separate license. Obviously required from 8 or 8.5 on. I have no clue on the cost.
( Since my test in NX7.5 only required the UG_KF_execute.)
Tomas
Ok, good to know. Thanks!
JHTH
I would assume you would need to have NX30624 (NX Greater China Toolkit) added to your license to be able to use it now.
Ask your reseller for pricing.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.1
