Gearbox Lubrication Calculations
pakgears
I have very little experience/knowledge of fluid flow calculations and I would like some help answering some questions that were posed to me. These questions concern a gearbox with a gerotor oil pump used for gear mesh spray lubrication.
Here is what I know:
The sump from which the pump draws is constantly replenished. Oil enters the pump through a Ø.50" hole. The pump is running at 7000 rev/min. The pump's theoretical displacement is 0.325 in³/rev. Oil exits the pump through a Ø.50" hole. After exiting the pump, the oil enters a sprayer with two exit holes, each Ø.063" in diameter. The oil is SAE Grade 75W-90, viscosity index 106 cst @ 40°C and density 0.859 kg/l. Let's assume an oil temp. of 40°C.
From this information, can I calculate the oil pressure in the line between the sprayer and the pump? If not, what else do I need to know/define? If I can calculate the pressure, how is it done? Let's assume I can neglect piping losses, if that helps.
Thanks in advance for any help.
Thanks for posting, crysta1c1ear. Yes, the question was posted in two forums. I am just trying to plug into two sets of experts because I thought the question was applicable to both pump and piping engineering, two fields in which I hold no claim to much knowledge - that is why I am writing and why most people write from what I have seen. If this is not an accepted practice, I apologize. I am not clear on the purpose or intent of your post. Can you help me answer the questions I posed?
Also, crysta1c1ear, I am not a student in the academic sense anymore. I do try to learn something new every day, however, and I look forward to any help you can provide regarding my questions!
