"Hello.
Recently I saw in a blog that the output shaft of a gear stands more load than the inpout shaft. This surprised me because I remembered that the load is constant in all the shafts. My questions are:
- Is it this way?
- Which is the gear that failS before input or output? and why?
- Which is the rolling bearing that fails before input or output? and why?
- Somebody has a link or pdf with gears general maintenance information?"
In the simplest case, a gearbox absorbs only torque on both ends. In the real world, additional loads come from:
- misalignment of couplings
- bending or axial load caused by overhung masses, belt tensions, imbalances, or other external load sources. A great example is mounting a reducer and letting the weight of the reducer rest on the shaft - the gearbox itself is the overhung weight.
- variances in torque can also contribute, because torque usually creates axial and bending reactions within the gearbox.
These things all directly effect the bearings, particularly the ones holding the shaft with the additional load. However due to the normal flex of the components you'll have misalignment added to the gearing, which can severely reduce the effective life of the gearing. If the load is on the output shaft you'll tend to see the failure on the output gearing. This is why you can buy not just plain gear reducers, but also crusher drives, mixer drives, conveyor drives, etc. Those specialty drives are reinforced to handle the additional external loads in the most cost-effective and reliable way possible (putting bigger generic gear reducers is not usually cost-effective). Improper understanding of external loads is a big reason for persistent drive failures.
Maintenance boils down to this:
- Keep the lubricant clean and free of water. Use the correct lubricant for the application, including site-specific factors such as ambient temperature and duty. Change the lubricant when it's no longer within specifications.
- Monitor temperatures and gear wear. Repair the drive when damage is discovered.
- Monitor bearing temperatures and bearing wear. Repair the drive when damage is discovered.
I don't have a single PDF reference to offer on that but those are the main topics and you can research them independently.
David
