nds88
- May 31, 2021
- 22
I recently worked on a project that had many components that required high precision tolerancing at interfaces to control a desired outcome. I don't have a ton of GD&T experience and so I got some help from others around me at the time. I often felt like the possibilities of misalignment were endlessly spiraling. Has anyone else experienced this? I thought maybe in Aerospace or R&D this might be common.
What methods did you use to do a stack-up or tolerance analysis? Are there any modernized software methods? I noticed Solidworks has a feature but I found it hard to learn without spending significant time in it. I ended up doing everything I could by hand or excel.
