kelleyl
- Nov 24, 2014
- 2
I am trying to design for a special shower drainage situation.
I have two showers that together drain 3gpm into a long shallow trench/depression in the floor to a 2" floor drain pipe, 5" square grate strainer.
The CPC says 2DFU for a floor drain, and 2DFU is the equivalent of 1gpm... So I am assuming that means my floor drain will only drain 1gal of water per minute.
So my question is does the shower in at 3gpm minus the drain out at 1 gpm equal 2gpm consistently collecting, or am I missing a key idea? Otherwise this seems it wouldn't work.
Any insight is appreciated!
