I have a quandary that appears quite often on prints I work with.
A given part has a general profile to govern undimensioned features. On said part I have a blind, threaded hole called out on the print to Y14.6 standards. There is a section view of this hole with a cylinder depth called out However a drill tip is modeled with the part. This drill tip is not specifically defined on the print. Does the general profile apply to the cone formed by the modeled drill tip?
I would like to argue that it does not apply as the drill tip geometry would then require that a drill be used to form the hole rather than some other machining process. Especially when this drill tip is likely automatically modeled by a hole wizard in the designer’s CAD program.
A further slippery slope, do I need my CMM to construct a cone for the drill tip to ensure that the profile is met at the base of the hole?
