Generative Sheetmetal Design vs DXF 1
asimovic
4
Hi! How can I update (automatically) existing dfx file (created from Generative Sheetmetal Design1s module, command Save as DXF), when I change original CATPart?
Ferdo, I generate CATPart in GSD. Then I use command Save as DXF. Next step: open generated dxf file (after command Save as DXF) and create Text box with some information (material, thickness etc) and I save it again like dxf. So, if I change original CATPart (Generative Sheetmetal Design), I mean about dimensions-example, and after that when I open exist dxf, I expect to сее new contour with old text box with old informations. But that doesn't happen. I mean, in this case doesn`t links between CATPart and dxf file (somthing like between CATPart and CATDrawing). Why?
There is no link, for the same reason that if you created a plot that was sent to a printer that the software would not, every time you saved, spool up another print job with the latest output. Drawing eXchange Format is a one-way trip to send to other people.
Ok. But what happens with same case in CATIA V6 and 3SExperience?
to avoid confusion:
GSD == Generative Shape Design
SMD == Generative Sheet Metal Design
but dxf will still be dxf, standardized (one-way-) output...
regards,
LWolf
DXF files are not CATIA files and will not update like CATIA files.
Save as DXF function in SMD is intended to provide a flat profile of the sheetmetal part in order to feed a production machine.
If you want a drawing you should do a CATDrawing file from your Part. This will update. If you need a DXF to exchange with other party, then make a DXF from the CATDRawing.
Eric N.
itsmyjob wrote:
"Save as DXF function in SMD is intended to provide a flat profile of the sheetmetal part in order to feed a production machine".
Ok, you can create dxf from CATIA software but you haven`t ability to update this type of files if you change original CATpart (Generative Sheet Metal Design). Ridiculously?
itsmyjob wrote:
"If you want a drawing you should do a CATDrawing file from your Part. This will update. If you need a DXF to exchange with other party, then make a DXF from the CATDRawing." It will be a half solution, I know that option.
I want to thank everyone who participated in the discussion.
dura DXF sed DXF
Eric N.
