engpes
- Feb 10, 2010
- 175
I have a generator inside a sound reduction enclosure and am trying to determine the decibel level directly outside of the enclosure. I know there are quite a few variables to nail down, but is there a method to calculating an estimated noise level if I determine the following:
1.). Enclosure steel construction
2.). Insulation material
3.). Generator dB level and frequency
Is there a way to determine a noise reduction coefficient? Can this be used to estimate levels?
Obviously this not a type of application we deal with every day, but would appreciate any advice on the above. Thank you.
