I have a 220KVA Iveco generator with Deep Sea Electronics Model 521 Automatic start and Iveco Aifo Speed Control Unit installed. This then goes to a Star Delta control box that runs a 55KW motor on a granulator (for the plastic industry. It is a Blackfiars HD67 granulator)
I am having a problem with the generator. It seems to be hunting all the time in time with the granulator working. I have checked for fuel leaks and made sure that all the connections are tight. I am about 100% sure that the problem isn't an air leak in the fuel.
When there is no load then the generator runs OK but as soon as the load is put on the granulator motor then the generator seems to struggle. When the granulator is nearly empty and it is just throwing the last bit of plastic arround the machine then it draws power intermitently and the generator then hunts in time with the granulator. (at this point it isn't drawing many more amps than at idle. between 30 and 60) Eventually it just stops (sometimes after 3/4 hour sometimes 1/4 hour) and then sometimes needs bleeding to start again but not all the time. I suspect this is because the hunting causes a vacum in the pump and is not the actual cause of the problem but a symtom.
We are now stuck so any thoughts on this would be most appreciated.
Cheers
Lenny
Cheers
Lenny
