Wilbur
- Feb 18, 2002
- 1
I am installing a new 480Y/277 500kw generator. I have received conflicting data on what to do with the neutral of the generator. The manufacturer does not wish to make a
recommendation. The manuf's rep says to float the neutral.
My idea was to run a neutral from the generator to the
transfer switch and bond the neutral to the system ground.
The 480v distribution is 3W, so there is no neutral to connect to. With a generator of this size, it is impractical to install a transformer to develop a neutral.
Any suggestions?
Any suggestions?
