nikhilgajjar
we have installed SEGC make , RWE type rotor earth fault relay for our 11 MW steam turbine generator.
Relay aux. supply is of 110 VAC and output of the relay is 49 Volt ac. Here we have a confussion:
1. From relay manual it is understood that for rotor earth fault measuring circuit, relay will impressed above 20 VAC.
Now with 20 vAC even with solid eath fault relay is not at all operating. So what could be the reason for?
So my question is :
1. What should be the relay output for rotor earth fault measurment.
pls. clear my confusion.
regards
nikhil
So my question is :
regards
nikhil
