pithpal
- Oct 21, 2005
- 50
Hi Everybody,
I was wondering, if you could comment on a suggestion made by my senior engineer. If we have an emergency diesel generator, and it is star connected but not sure if it is 3 oh 4 wire or only 3ph 3 wire, and it is connected to an ASCO power transfer switch. Now, through this switch there is a panel with disconnects which is hooked to the elevator but there are some spare disconnects available, which we can use for emergency lighting. Now this 3 ph 3 wire star is 416 and we need 240 V.
He suggested that we just use the building ground as the neutral and make it as 240 V and then use for lighting panel. Does this sound all right ?. I beleive it, but does it violate any code. Any word from you will do some contribution.
