Evening all, a discussion came up today at work (national hire company that supplies rental power) about some of the generating sets in the fleet that can be switched from 50/60hz on the control panel. The set is an SDMO 200kva. (r220)
I was unable to switch the set over to 60hz due to password restrictions but the discussion was what the generator does when you do switch it over.
Im aware on smaller generators that the frequency is set by the engine rpm 50hz 1500, 60hz 1800. I assumed that this would be the same on the set in question as the engine is electrically governed by the control panel. I assumed that when switched the engine will rev to 1800 and the AVR will adjust the voltage accordingly.
I was told this was incorrect and that the engine speed will remain the same as the frequency is adjusted by the amount of rare earth magnets being used in the rotor/stator.
My colleague couldn't tell me where this information came from or elaborate on the finer details.
Could anyone verify if this is true or not? I have scoured the internet and cannot find much if any useful information on these rare earth magnets and just wanted to be sure that it wasn't shinfo.
Cheers.
Cheers.
