i see bigh's position and it's not unreasonable depending on the contractual agreements and predetermined scopes of services. the mse designer is designing a geotechnical structure...if they cannot evaluate their own structures, then they should not be designing the things. the geotechnical firm is typically "reduced" to simply being the geotechnical testing firm and performing the testing as requested by the designer and then providing all the test results, boring data, etc to the designer for their assessment. and again, this goes back to certain designers i have dealt with the choose to completely disclaim any all liability for the wall, wall design, performance, etc. on to the owner and owner's geotech. additionally, when they ask for the specific parameters that they should directly input to their software, i will always refuse. if i am going to give them that, i'll just cut out the middle man and provide the design myself. if these certain designers would take a reasonable approach, then i would be willing to cooperate...and i do cooperate with other designers that do their job and accept their responsibility. when a sizable wall goes south, the geotech can easily be stuck with many hundreds of thousands of dollars in litigation related fees regardless of what they did or did not do on the job.
so have a pre-project meeting that includes the geotech, designer, civil, and owner to discuss who does what and what is expected.
