Geometric Dimensioning & Tolerancing 1
brakemeister
Automotive
Aug 15, 2002
41
Can anyone tell me if there is a standard which replaces ANSI/ASME Y14.5?
ASME Y14.5M exists and still active. You may find the standards by searching the originating organization instead of ANSI. The current version is ASME Y14.5M-1994.
John
jsummerfield is correct.
Curious, why would you want to replace it? Or did you hear somewhere it was replaced?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
There is a new standard to supplement Y14.5. Check out ASME Y14.41-2003.
can anyone explain the proper use of
PROFILE when the part is dimensioned using +/-
tolerances instead of BASIC dimensions?
mm2c, try reposting your question in forum1103
[green]"I think there is a world market for maybe five computers."[/green]
Thomas Watson, chairman of IBM, 1943.
Have you read faq731-376 to make the best use of Eng-Tips Forums?
You can NOT use +/- tolerancing with profile.
All dimensions MUST be basic for the outside profile.
We just started a GD&T training class this morning and the instructor emphasised this point.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I concur w/ looslib.
using a +/- tol you are done right there.
Stacking another tol on top of that with Profile is not an option.
Phil Zygiel
Project Engineer/Design Checker
Ricardo
See thread1103-118368 for a discussion of profile tolerancing.
