Geometrical constraints in Drafting Module? 1
Ard88
10
Hi everyone,
I am quite new to Catia. I am currently using a V5R20 version. I would like to know if it is possible to use constraints when you are in a drawing view. I see here is a guide:
but my problem is that I don't see the Geometrical Constraints tool in my toolsbar. I normally see it when I am in sketcher, but not when I am in drafting. Someone have any hints if there is possibility to show it also in drafting module?
Thanks you all!
ARD
Little riddle "A roman enters in a bar and raise his index and middle fingers. How many beers did he order?"
Yes, drafting has the Geometrical Constraints tool.
If it is not shown, you need to bring it by Customize option...
But I still do not understand what you want to do...……..
Why do you need to constrain geometry in 2D?
CAD 2015
CAD 2015
Thanks cad2015,
yes i was able to bring it there too.
Actually I found out it's not really essential for me. When you activate the view, you can draw any line/point/circle you need, constrain it to the geometry (automatically highlighting to a green colour by def) and then hide/delete it. I found this method very useful!
Actually I have another question related to this: when you create a point/line in an activated view, you have the possibility to right click and 'fix' it. Why would you need it? I see that, when the view is activated, all geometry are moving together all the same.
ARD
To make it stay in one place despite being "driven" by a constraint.
Geometry is linked to view's axis system, that's why it moves when a view is moved.
You still didn't answer my question:
What are you trying to do?
CAD 2015
Thanks little cthuhlu,
Cad2015 i was trying to add a line parallel to a a particular edge. My first approach was to use geom. constraints like in Sketcher but now I found out by working on it that you are not gonna need them actually. I see it's easier to draw lines on geometry / or parallel / or perpendicular, move them around and change their aspect/size. Just a different approach, I think I found my way. Ciao!
