Geometry Preferences in Femap 1
Grozozo
Student
Feb 8, 2022
11
Hello there!
I have strugle to find meaning of set up in Geometry/Model tab. I understand unit consistense and that all right, there is a list in documentation, but how to know which set up is for mN-mm-s, N-mm-s or N-m-s?
Grozozo.
Google - Unit System - Siemens Communities. You will need to set scales factor based on m or mm.
The unit system in some FEA software is user defined. You would be responsible for setting correct unit systems. Search consistent unit system table from Abaqus.
If you want to use 'mm' then units will be Force-Distance-mass-time => N-mm-metric tonne(10^3kg)-s
If you want to use 'm' then units will be Force-Distance-mass-time => N-m-kg-s
Great thanks for clearing this!
Grozozo.
