Geostar (non-linear) how to release constraints
JAGaynor
Marine/Ocean
Feb 17, 2007
3
Hello - please disregard my previous post... I'm hoping that the Lack responses was only my vagueness and not a lack of members using COSMOS anymore!
searching online and finding early press releases, I read that one of the strengths of Cosmos/m / Geostar is the ability to release and activate constraints during a non linear analysis...
Anyone know how to specifically do this?
here is my problem:
I am trying to analysis a 3d beam / truss structure with adjustable linkages...using temp curves to pretension and adjust the structure. getting this all to run to equilibrium is very tricky. I'd like to fix a few points as I bring the structure up to tension - and then release these constraints for the subsequent time steps.
I have time/temp curve defined, and associated the point constraint to this - but as far as I can figure out this just allows me to change it from 0 (fixed) to some value (prescribed displacement) - not completely disable it.
Anyone know a better way to do this?
thanks
Andrew
Hello!,
It's years I don't use COSMOS/M GEOSTAR anymore, but the only feature available in any serious FEA code is RESTART feature:
Suppose that a Nonlinear problem diverged at solution step number 5. Activating restart feature you can change the solution time increment, or some other parameters like loads & BCs. If the restart feature is OFF and you run the nonlinear analysis again, the solution will start from step 1 ignoring previous results. If the restart flag is ON, the solution will continue from step 5.
Good luck!.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: Blog de FEMAP & NX Nastran:
I'm racking my brain for this. I've done it before, but I don't have the docs in front of me. There is a way in the time curve to apply a constraint and then release it at a set time. I seem to remember some "magic" number like "999" or "-999" but don't quote me on that.
My 2 cents.
TOP
CSWP, BSSE
"Node news is good news."
1E-8 as a value in a time step.
If you do it in one jump you have to use a Dynamic Solution. If you ramp it a little you can get away with a Standard non-linear solution.
You have to activate the time curve before you define the constraint that will be effected by it.
For example executing this:
Code:
CURDEF, 1, 0,1,1,1e-8,2,1e-8
will turn off whatever boundary conditions were created after it at a time value of 1.
TOP
CSWP, BSSE
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
