Hi VoyageofDiscovery, Hi Focht3,
Thank you for the reference and insights. I read the reference. It considers a failure mechanism. I know that there is a tendency to look at soil creep as a slope sliding failure mechanism, and it may very well be that the progressive creep eventually leads to a slope failure, in which case then the force becomes that due to the sliding mechanism. However, when creep is still just a creep and not yet a mechanism, the forces applied to the pile or pier will be due to the viscoelastic flow. The creep takes place when the moisture content of a clayey (expansive) soil increases during the wet season causing it to expand perpendicular to the surface slope. Therefore a sandy soil would have a smaller creep and consequently exerts a smaller creep force on the pile. A clayey soil, on the other hand, significantly softens when moisture content is increased. Therefore, the creep force cannot be considered as a function of global shear strength of the overburden material. If we can envisage the creep phenomenon as the overall movement of about 0.1 inch per year of the top 3 or 4 feet of the overburden soils, then the force I imagine should not be much greater than the active earth pressure acting as an inverted trangle (1/3 H from top; H is creep zone depth)on the pile.
