user277418
- Jul 11, 2017
- 86
Hi comrades
Designing a retaining wall.
Structural layering from top to bottom: the cast-in-place retaining wall base > blinding (weak concrete thin layer or geotextile) if necessary > crushed rock pad 0,5 m mainly to avoid capillary effect, but have to be compacted properly to provide good base > bedrock. Peak underground water level about 10 m lower. Bearing pressure and settlement are not a problem.
1. Do I need a blinding layer to avoid concrete seeping to the crushed stone pad? I always used concrete blinding before, but right now designing it in different country and, it seems to me, no one use it here in such cases. Internet surfing gave a lot of controversial information. Someone never heard about the concrete seeping, someone horrified to don't have the blinding layer. Have a guess, that the concrete seeping depends a lot on concrete slump grade and concrete used for foundations isn't very slumpy usually.
2. Ok, if the blinding layer is still required. Is it acceptable to use geotextile/filter fabric/filter cloth instead of blinding concrete layer under the cast-in-place retaining wall base on top of the crushed stone pad? May geotextile reduce friction coefficient in the case? For retaining structures it is important.
PS: sorry for my English, just in case
Best regards
Best regards
