get err in nx11 sketchInPlaceBuilder1 = workPart.Sketches.CreateSketchInPlaceBuilder(nullSketch)
Ehaviv
Computer
IL
Hi
Is it OK that this statement
worked OK in nx8.5 and throw error in nx11
the API reference say in nx11 ues CreateSketchInPlaceBuilder2 instead.
because CreateSketchInPlaceBuilder is obsolete
Do in every NX released I need to check and rewrite my apps !
Thank you in advanced.
Yes. If you are compiling your code, you will need to reference the new NX dlls and recompile for each new (major) release. If the code compiles successfully, I'd suggest running some test cases before releasing it to the users. If you get errors, it is time to dig in and find out why. If you are not compiling your code, you should still test on new NX releases.
This is true of programming in general and the issue is not specific to the NXOpen API. Those that write and maintain the API do what they can to keep the function signatures the same between releases (so as to not disrupt existing code), but sometimes this isn't possible and new functions make existing ones obsolete.
www.nxjournaling.com
Cowski thank you
This very disappointing
But we live with it.
Thank you again.
