Get point location from VBA6
666vito
Industrial
IT
hi
I use solid edge 14 and visual basic 6. At the end of my work I'll open a macro from SE to work with my program
I try to explain my problem. I have an SE assembly file on this file I make a sketch. This sketch is made only of a line. All the
sketch is in a plane, I have a 2-d sketch. I'd like to get the line's start/end point (in whichever sistem of coordinate). At the end I
should be have a matrix or a table make of start/end point. For examble:
Line1 (3,3)-(5,7)
LIne2(5,7)-(8,11)...........................
Start point of second line is end point of first line.......................All points have one coordinate equal for every point ( sketch is in a plane)
I study how interrogate a SE file from visual basic but I can't resolve this problem........
Can you help me? or this is impossible using SE and VB6? Thanks and sorry for my english
this code fragment should work. You must still be within the
sketch and the file must be an assembly one (all quick & dirty):
Private mApp As SolidEdgeFramework.Application
Private mAsm As AssemblyDocument
Private objProf As Profile
Private objLine2d As Line2d
Private dx As Double
Private Sub getLineCoord()
Set mApp = GetObject(, "SolidEdge.Application")
Set mAsm = mApp.ActiveDocument
Dim dy As Double
Set objProf = mAsm.ActiveSketch
For Each objLine2d In objProf.Lines2d
Call objLine2d.GetEndPoint(dx, dy)
Call objLine2d.GetStartPoint(dx, dy)
'... your coding here
Next objLine2d
Set mAsm = Nothing
Set objProf = Nothing
Set objLine2d = Nothing
Set mApp = Nothing
End Sub
dy
Thanks Donyoung
I'll try your code in next days
by
