Get stress/temperature at nodes in assembly set
Taylor W
Geotechnical
Feb 7, 2023
14
Hello all,
I'm trying to find a way to get the Mises stress and temperature at nodes on an edge using a script. I've created an assembly set at that edge, and here's roughly what I'm currently doing:
o1 = session.openOdb(name='myODB.odb')
resultsSet = o1.rootAssembly.nodeSets['Set-1']
temps = o1.steps['Step-1'].frames[-1].fieldOutputs['TEMP']
resultsSetTemps = temps.getSubset(region=resultsSet)
print wellBottomTemp.values
However, with stresses and temperatures, it just prints an empty list. What am I doing wrong?
Check the documentation chapter Scripting --> Accessing an Output Database --> Using the Abaqus Scripting Interface to access an output database --> Reading from an output database --> Using regions to read a subset of field output data. It shows how to print field output from a given set.
The problem is that the TEMP field output contains values at element integration points and you are trying to extract a nodal subset from it. Use either fieldOutputs['NT11'] or extrapolate the integration point values to nodes using getSubset(region=resultsSet, position=ELEMENT_NODAL).
