Get the linked Attribute value of a note (VBA)
Maddy02
114
Hi all,
I have a note in a drawing which displays the value of an attribute from part document
i would like to
1. check what property this has been linked to
2. link if it is not linked to the desire property.
kindly let me know how could i achieve this thro vba.
Maddy
Dear CorBlimeyLimey
Thanks for the reply.
I would like to know how to achieve it through macro (VBA)
Maddy
Hi handleman
yes you are right.
i need to set the value of a note to a attribute if it is not linked to it.
getting the linked property is ok but how to set it.
Maddy
If you set the text to the same thing that's returned by PropertyLinkedText, it will link automatically.
-handleman, CSWP (The new, easy test)
Hi handleman,
Will try and revert.
Maddy
