GetCoordinates of a Point in Drawing View
PrasannaNX
Automotive
Aug 5, 2014
31
I am using Catia VBA Editor for finding the coordinates of a point in drawing view.
For some reason "GetCoordinates" method of Point2d object doesn't return anything in VBA.
The same is working fine with C#.
Exact issue as mentioned in this thread:
Alternatively:
Manually i tried using "Measure Item" in Catia and selected the point in drawing view which gives me the Coordinates of the point relative to the view.
How do i automate Measure Item" in Drawing Document.
Measurable.GetMeasurable(CATIAReference iMeasuredItem) needs CATIAReference as parameter.
How can i create CATIAReference for an object in drawing document?
Like in PartDoc "Partdocument.Part.CreateReferenceFromObject"
How do i get in DrawingDoc "Drawingdocument.?"
Thanks,
Prasanna M
All methods work the same whatever language you use.
I believe you get "Function or interface resteicted" error which may be swallowed by uneducated use of "On Error" statements.
Post your code.
You are correct. I overlooked the code.
Thanks.
Code:
Sub Main()
Dim catDrwDoc As DrawingDocument
Set catDrwDoc = CATIA.ActiveDocument
Dim catDrwSel As Selection
Dim catDrwSelLb As Object
Set catDrwSel = catDrwDoc.Selection
Set catDrwSelLb = catDrwSel
Dim objFilter(0) As Variant
objFilter(0) = "Point2D"
Dim strStatus As String
strStatus = catDrwSelLb.SelectElement2(objFilter, "Select point in drawing view", False)
Dim catDrwViewPoint As Point2D
Dim catDrwViewPointLB As Object
If strStatus = "Normal" Then
    Set catDrwViewPoint = catDrwSel.Item2(1).Value
    Set catDrwViewPointLB = catDrwViewPoint
End If
Dim arrCoords(2)
catDrwViewPointLB.GetCoordinates arrCoords
MsgBox "X Coord : " + CStr(arrCoords(0)) + Chr(10) + "Y Coord : " + CStr(arrCoords(1)) + Chr(10)
End Sub
Thank for posting the code.
Note to everyone how "interface marked as restricted" error was worked around by typing actual Selection object "as Object"
@Little Cthulhu,
Follow-up question of my original post.
Will there be a need of using CATIAReference object in drawing?
If yes, how do i actually create a CATIAReference in drawing document?
Just to know in case i come across a case where i need to use CATIAReference in drawing in future.
Thanks,
Prasanna M
