  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Getting a preview of the file when loading from directory 1
LMTDCS
30
When opening an NX 7.5 file I can not get the preview of the file to show. All that is present is the Siemens nx std icon. All other files show the file content (solide works--acad--ect). What am I missing..NX or operating system??
Chris
NX7.5.2.5
windows vista
Make sure that your parts have previews saved:
File -> Properties
getfile.aspx
Also the see the customer defaults for how to define for new blank parts:
getfile.aspx
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, Beta NX8.0.0.23
Anthony,
Thank you for the response. I have all these settings already set. Any other suggestions????
From Windows, select "Start -> Run" and enter:
regsvr32 "C:\Program Files\UGS\NX 7.5\UGII\ugshext.dll"
assuming that's where NX is installed.
Anthony Galante
Anthony,
That did the trick.
Thank you!
I got a problem at UGNX 7.5 in two machines. The UG is not saving the preview. I checked the configuration but it’s all as recommended. This problem is happening only in two machines. I checked the OS version and setting…..it’s all OK.
The both machines are SUN Ultra 20 with XP 32 Bits SP3.
Does anybody have any idea about this problem?
 http://files.engineering.com/getfile.aspx?folder=d55fe1b1-0ddf-41f4-8003-344b0678f771&file=ug.JPG
