Getting actual deflection values in ABAQUS
wazir9
Automotive
Aug 21, 2012
6
Hello all,
I have been working on a bumper design in abaqus and getting stress and strain values as output.
But i want the maximum deflection value in mm in the bumper during the crash.
How can i generate that?
Also the maximum force being exerted on the bumper?
Please help!
I never use that option but I think it can be answer for your question.
Please take a look here:
Abaqus Analysis User's Manual, 4.1.3 Output to the output database, Requesting maximum, minimum, or absolute maximum values for an output request
Bartosz
If by deflection you just mean movement, request U (is done by default normally).
Force is either Reaction Force (RF) or Contact Force (CFORCE), depending on your modeling strategy.
You can see the max in contour options -> limits. But for force, a summation of all (or a certain region of) force vectors sounds better to me (operate on XY data)
so that means if i want deflection in the Y direction, i should choose U2 from field output ?? right??
Did you not check the displacements before looking at stresses/strains?
See faq569-1083 for details on how to make best use of Eng-Tips.com
I am pretty new to ABAQUS and learning from scratch. I am currently trying to model a weld simulation to determine the temperature and stress distribution after cooling. I tried using the heat transfer step to determine the temperature distribution afterwards, but there was no temperature recorded. Could somebody give me a hint on the best way to model the weld and perform the simulation? Thanks.
