siavash1111
- Apr 14, 2012
- 13
Hi
anyone in this forum can advice me min preheat and post weld heat treatment temperature which is required for welding of GGG 60 nodular cast Iron(DIN 1693). the welding electrode which i want to use for this cast iron is AWS SFA‐5.15 E NiFe-Cl
the damage part is piston of a air hammer with 31 cm diameter. a segment of this piston around 11*5*5 cm should be repaired .can anyone advice a guide line
Thank You in advance
