Thanks for ensuring my narritive makes sense...
I too have search, looking for a system like Drexl appears to be discribing. I found that youtube. that system appears to be similair to what each of us have presented, except the vidio's narrative is either misleading or just incomplete. I noticed at 0:54 to 0:58 there is a connection to the supply piping teeing off to a control valve that then is piped to the condensor, thus the header unloader valve for when the HP leak off becomes excessive for LP sealing. then at 1:01 to 1:04, you can notice that sealing steam is going towards the HP seal
that HP leak off that goes accross the top does not appear to used by the seal, but just a means to utilize some of HP leak off for making MWs and reduce the HP leakoff going to feed the seal steam header.
Durring searching, I did notice a "patent" drawing that look like it had seperate pressure regulating valves for the LP and HP seal, but the link to a readable drawing was dead.
"Tuning" the pnumatic controllers on the GE system was pure Voodo. 20 years ago, we came up with settings that were suppose to be suppleid in GEKs. without that info from the factory or able to find my old notes, it becomes the most difficult challange to a new unit since you need the operating extreme conditions to gather response and asking for a full load trip for testing is not appreacaite by any utility. where with the old MHC regulator, all the controlling engineer (lead/lag/gains & overlap) was bult into it, just get the linkage in good order and it worked
I am very curoius about Drexls system and hope we can see a P&ID. it is still nice to learn
