Hi.
I am designing a glass shelf that is made of 3/4" thk tempered glass and is 23" wide by 26" deep (front edge to back edge). This shelf is supported on the sides of the shelf only at the very rear by 4 clamping type shelf brackets, 2 per side. The center to center distance between the clamps is 5 1/2 inches. This shelf will need to support a weight of 35 lbs centered on this shelf and 8 from the front edge of the shelf.
How do I analyze whether this shelf will be adequately strong to hold this weight? How do I break this problem down to confidently say that this shelf is strong enough to support this weight?
See my attached pdf file.
Thanks to all in advance
