Has anyone sized a PSV on the glycol regen reboiler? What would be case here?
Rich glycol from the flash drum level control valve goes to the still column that opens to atmosphere with packing inside. The rich glycol going into the reboiler is heated by the directly fired firetube, and then goes to the stripping column and surge drum.
Will this be a fire, thermal, control valve failure case? Another thing is, since the still column is open to atmosphere, is a PSV necessary considering the packing inside the still column?
Thanks.
Thanks.
