KirbyWan
Aerospace
- Apr 18, 2008
- 583
Howdy all,
What's some good wording to put in the notes of a drawing to state that the fabrication is controlled by the model so drawing details are incomplete.
My thoughts are:
"Fabrication of part is controlled by model geometry contained in file "PARTXXXX.STL" derived from 3D CAD model. Drawing dimensions are for reference only and may be incomplete."
So I'm printing a complex shaped HX header that I plan on 3D printing. I want to have a drawing to go through our regular signoff process and document approval, but since this will be fabricated directly from an STL derived from the model, there isn't a lot of value in creating a complex drawing. that will not be used. Some of the obvious external dimensions may be used to check part fitup.
Has this been handled before? Are there other suggestions for this note?
Thanks,
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
My thoughts are:
Thanks,
-Kirby
Kirby Wilkerson
