Just finished looking for some Goulds pump data, the 3196 being discussed in another thread.
Went to the Goulds website and was told to download some pump selection active x program. OK.
Had to register. OK, filled in all that stuff. At least a 10 character user name. Finally.
Had to login. OK logged in.
I downloaded the PSS component and started it up. Couldn't find any pump curves. It asked for all the data needed to make a pump selection. I filled in a bunch, should be enough to get the curve... I thought. Still no curve apparent anywhere, nor any method to simply find a curve for an already existing pump that doesn't need to be selected. I found the whole "selection" process so inconvenient that I wrote to the support group and told them that I would not specify a single Goulds pump until they improved the access to pump curve data.
Still don't have the curve data.
What were they thinking?
"If everything seems under control, you're just not moving fast enough."
- Mario Andretti- When asked about transient hydraulics
