Jakob von Essen
I get the graphical issue shown in the attached picture when rendering frames for an animation using Menu-View-Visualization-Create Animation.
Changing the faceting or visualization options (per instructions provided on this and the official Siemens forum) didn't fix the issue, nor did making the bodies thicker.
I've had this issue only after adding more parts to my assembly, but removing those same parts from the assembly doesn't make the weirdness go away.
If I stop the rendering and rotate the view, the display goes back to normal. Since I have over 3000 frames to render, doing it manually is not an option though. Is there any way to make NX do the same "rotating one step to one side and then one step back" sequence before saving each render?
Thank you!
Thank you!
