hi all
I want to simulate the weight of a structure using concetrated mass at certain points of the mesh. However I am not so sure whether by applying inertial load over the entire model, by this way nastran takes under consideration the weight at those points. The procedure I used was teh following:
1)created an concetrated mass at a certain point of the structure 2) Applied an inertial load over the entire structure (with g=-1 in the y direction).
The rest of the structure is modelled with materials that have no density and shell elements (I thought that by this way the model would be computationally more efficient)
Was this the correct way?
Cheers
Cheers
