donatz68
Geotechnical
- Mar 14, 2008
- 2
I am working on a conceptual design for a reservoir dam. The dam will be roughly 1600 meters long and consists of a gated spillway, an RCC section designed for auxiliary overtopping (roughly 460m long), and an earth embankment section (835m) strictly to contain water and not designed to be overtopped. The water table is at 7 meters below existing ground surface and competent rock is at roughly 30 meters below ground excavation. I am proposing to excavate to just above water table and place drilled shafts to competent rock (the dam will be roughly 30 meters in height from water table elevation). I am looking for any insight or supplemental references on drilled shafts foundations supporting gravity dams. If anyone can help, it would be greatly appreciated. Thanks.
